Unresponsive Graphic Links on Advanced Display
  • Unresponsive Graphic Links on Advanced Display
  • DavidChild
    DavidChild
  • PeterEdvik
    PeterEdvik
Janeway PeterEdvik Janeway
‎2020-03-31 06:37 AM
on ‎2020-03-31 06:37 AM
Some links in graphics are unresponsive on Advanced Display when running EBO 1.9.4.
  • Building Operation Advanced Display V2
  • Building Operation Advanced Display V3
  • EcoStruxure Building Operation v. 1.9.4
The links that are unresponsive are trying to open the target in a floating window. This is not supported on Advanced Display with WebStation when using EBO v. 1.9.4. More specifically the graphics script function is not supported under the conditions mentioned above.
invoke("Link", "OpenInFloatingWindow");
Use alternative arguments other than "OpenInFloatingWindow" such as "OpenInNewWindow". See the WebHelp Section Invoke Function for more information about the Invoke function.
  • PeterEdvik20
