SpaceLogic SLO/SLR Label showing incorrect kL range value
  • SpaceLogic SLO/SLR Label showing incorrect kL range value
Gary Schneider Alumni (Retired)
‎2022-08-24 08:37 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:33 AM
The SLO Label shows an incorrect value range for kL.
Field Devices
SpaceLogic SLO series Lux sensor
Warning
Hazard of Electric Shock: Remove all power from all devices before removing any covers or doors of the system. Disconnect power at the device and at the power source.
The label on the SLO shows the incorrect value range for kL.
SLO:
The product specification sheet states the Ranges for the jumper as: -
0 to 500 lx and 0 to 20 kLx
The range to 500 lx can be seen on the circuit board.
The product’s label shows 0 – 4kL
The manufacturer has confirmed the label is incorrect the value should be 500 lx,
New labels will be used in production from August 2022.
SLR:
The tense delivery situation during the pandemic, especially for electronic components, has forced the manufacturer to make technical changes to the SLR in order to stay able to continue to deliver reliably.
The range has extended from 0.4 to 0.5 kLux.
These changes are incorporated in the corresponding instructions, provided with the devices.
New labels will show the extended range.
Labels (4)
  • Field Devices
  • Satchwell BAS & Sigma
  • GaryMontague22
