SigmaX checks prior to transition into EBO
  • SigmaX checks prior to transition into EBO
Sisko DavidChild Sisko
‎2020-06-04 05:20 AM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:35 AM
Satchwell Sigma
SigmaX
Warning
Potential for Data Loss: The steps detailed in the resolution of this article may result in a loss of critical data if not performed properly. Before beginning these steps, make sure all important data is backed up in the event of data loss. If you are unsure or unfamiliar with any complex steps detailed in this article, please contact Product Support for assistance.
Doctor checks required prior to transitioning Sigma to EBO.
Preliminary checks steps to be taken to check a Sigma database is error free prior to a transition to EcoStruxure Building Operation (EBO).
This video will demonstrate how to use SigmaX, but it will not resolve any errors in the database. Any database errors can have been caused by a number of different reasons and will provide a report listing the errors so that they can be corrected.
This video with SigmaX is in three parts, the second SigmaX Quick Help Video will check for Duplicated Names and the third video will check for Programmable Objects with different types of RETURN statements.
When launching the SigmaX application, see the Knowledge Base articles for Side by Side errors and errors regarding missing SigmaX files should they occur.
  • Satchwell BAS & Sigma
Tags (2)
  • DavidChild20
  • DavidChild22
