SP-MRDM2 2 Door Mini Expander terminal block spacing
  • SP-MRDM2 2 Door Mini Expander terminal block spacing
  • DavidChild
    DavidChild
  • PeterEdvik
    PeterEdvik
Janeway PeterEdvik Janeway
‎2020-03-18 02:33 AM
Last Updated: Sisko DavidChild Sisko ‎2020-03-18 02:33 AM
What is spacing for the screw terminal blocks of the SP-MRDM2 2 Door Mini Expander, and what do the terminal blocks look like?
Security Expert
Security Expert 2 Door Mini Expander
Screw terminal block details needed for ordering spare parts.
The 2 Door Mini Expander uses two different screw terminal blocks. The lower is the normal terminal with 5.08 mm pitch labelled 2EDGK, and the upper is upside down, also 5.08 mm pitch and labelled 2EDGKF.
See also data on the manufacturer's website.
  • EcoStruxure Security Expert
  • PeterEdvik20
100% helpful (1/1)
