SP-MNR2 Compatibility
  • SP-MNR2 Compatibility
  • DavidChild
    DavidChild
  • PeterEdvik
    PeterEdvik
Janeway PeterEdvik Janeway
‎2020-03-23 01:57 AM
Is SP-MNR2 compatible with SP-C-WEB and SP-ACX? The documentation only refers to "controller" and not SP-C/SP-C-WEB/SP-ACX specifically.
Security Expert
  • Security Expert Security Purpose COMMS Expander (SP-MNR2)
  • Security Expert WEB Controller (SP-C-WEB)
  • Security Expert ACX PCB Controller (SP-ACX)
  • Security Expert Controller (SP-C)
Compatibility information needed to make a correct solution design.
The SP-MNR2 is compatible and will work with both the SP-C-WEB and the SP-ACX, as well as the SP-C, with no issues.
  • EcoStruxure Security Expert
  • PeterEdvik20
