Resolving Programmable Objects with different types of RETURN statements prior to EBO transition
  • Resolving Programmable Objects with different types of RETURN statements prior to EBO transition
  • DavidChild
    DavidChild
Sisko DavidChild Sisko
‎2022-04-05 06:28 AM
Warning
Potential for Data Loss: The steps detailed in the resolution of this article may result in a loss of critical data if not performed properly. Before beginning these steps, make sure all important data is backed up in the event of data loss. If you are unsure or unfamiliar with any complex steps detailed in this article, please contact Product Support for assistance.
SigmaX checks prior to transition into EBO
Satchwell Sigma
SigmaX
Programmable Object checks required prior to transitioning Sigma to EBO.
Programmable Object checks steps to be taken to check a Sigma database is free of more than one type of RETURN statement is used prior to a transition to EcoStruxure Building Operation (EBO).
This video will demonstrate how to use SigmaX to find and create a report of any Programmable Objects that are using more than one type of RETURN statement.
This video with SigmaX is the third of three videos, the first SigmaX Quick Help Video will check for Database Errors and the second video will check for Duplicated Names.
When launching the SigmaX application, see the Knowledge Base articles for Side by Side errors and errors regarding missing SigmaX files should they occur.
Labels (2)
  • Satchwell BAS & Sigma
  • DavidChild22
This is a heading
