Replacement for Satchwell AVUE, AVUX or AVUM mark 5 range
  • Replacement for Satchwell AVUE, AVUX or AVUM mark 5 range
Gary Schneider Alumni (Retired)
‎2022-10-19 05:50 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:33 AM
Need to replace an AVUE, AVUX or AVUM Mark 5 Actuator
Field Devices
  • AVUE5305
  • AVUE5355
  • AVUE5304
  • AVUE5354
  • AVUX5202
  • AVUM5601
Warning
Hazard of Electric Shock: Remove all power from all devices before removing any covers or doors of the system. Disconnect power at the device and at the power source.
Need to find a replacement for the obsolete AVUE, AVUX or AVUM Mark 5 actuator, that will allow the valve to be retained.
The AVU* Mark 5 range of actuators can be replaced from the MZ300S range.
  • AVUE5305 replace with MZ300S-24M
  • AVUE5355 replace with MZ300S-24M
  • AVUE5304 replace with MZ300S-24M
  • AVUE5354 replace with MZ300S-24M
  • AVUX5202 replace with MZ300S-24F
  • AVUM5601 replace with MZ300S-230F
The AVUE, AVUX, AVUM Mk 5 Datasheet is attached
MZ300S Specification sheet
MZ300S-24M Installation Instructions
MZ300S-24F Installation Instructions
MZ300S-230F Installation Instructions
  • Field Devices
  • GaryMontague22
100% helpful (2/2)
