Replacement for SPA1505 – SPA1506
  • Replacement for SPA1505 – SPA1506
  • Gary
    Gary
Gary Schneider Alumni (Retired)
‎2024-01-16 05:22 PM
on ‎2024-01-16 05:22 PM
Information for replacement for the SPA1505 and SPA1506
  • Field devices
  • Pressure sensors
"PA-00167 Sensors and Input Devices New SPP930 Relative Pressure Switch" suggests SPP930 replaces SPA 1505 and SPA 1506.
The link provided for the SPP930’s manufacturer’s data sheet, no longer works
SPP930 Part number 004701160 replaces the SPA 1505
SPP930 Part number 004701170 replaces the SPA 1506
The site wiring should be checked, to ensure it complies with replacement switches reduced current ratings.
SPA 1505/1506 data sheet
Huba Controls type 620/625 data sheet.
  • Field Devices
  • GaryMontague24
