Pulse Digital Output from a Continuum Conversion PWM Pulse Width Modulation
  • Pulse Digital Output from a Continuum Conversion PWM Pulse Width Modulation
  • DavidChild
    DavidChild
  • Dave_Shore
    Dave_Shore
Dave_Shore Schneider Alumni (Retired)
‎2019-09-19 05:45 AM
Last Updated: Sisko DavidChild Sisko ‎2019-09-19 05:46 AM
How is a Pulse Digital Output (BACnet Binary Output) created via a Continuum Conversion
  • b3 Controller
  • Infinet Controller
  • Continuum Conversion
A Continuum Infinet Output created as Elec Type Digital has Format $###, as below
When this is converted to EBO, a Type "BACnet Digital Output (Continuum) binary-output" is created.
The Format needs to be modified to ###.### or #.###, as below
The BACnet binary output created in the conversion will now be  a "Digital Pulsed Output"
Summary below
  • DavidShore19
50% helpful (1/2)
