PIBCV Valve
  • PIBCV Valve
  • DavidChild
    DavidChild
PIBCV Valve
Sisko DavidChild Sisko
‎2021-12-07 07:41 AM
on ‎2021-12-07 07:41 AM
PIBCV valves, stem up or stem down for valve open.
Field Devices
PIBCV Valves VP220, VP221, VP222, VP228
Further information required as to whether stem up or stem down for valve open position.
When the stem is up (retracted into the actuator) the valve is open.
Example:
  • Field Devices
  • DavidChild21
100% helpful (1/1)
