Notification Report Template creates blank data if External Log Storage is enabled
  • Notification Report Template creates blank data if External Log Storage is enabled
  • DavidChild
    DavidChild
  • Dave_Shore
    Dave_Shore
Dave_Shore Schneider Alumni (Retired)
‎2021-04-20 07:50 AM
on ‎2021-04-20 07:50 AM
  • External Log Storage
  • PostgreSLQ TimeScale
The default timeout for a Notification Report Template is 5s.
If External Log Storage is enabled and logs are being added to the report, the timeout may need to be increased.
The screenshot below shows a Notification Report Template where the default timeout of 5s caused an empty Report to be created (both an email and csv file were seen to be empty). Increasing the timeout to 20s resolves the issue.
  • DavidShore21
