Mixing Low and High voltage on same side of an CRS-HH-REL-10
  • Mixing Low and High voltage on same side of an CRS-HH-REL-10
Guinan MikaelKrantz Guinan
‎2025-04-14 04:20 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:31 AM
Why is it recommended to not mix high and low voltage connections on the same side of an CRS-HH-REL-10?
EcoStruxure Building Operation.
  • Building Operation Room Controller (RPC) 24 V
  • Building Operation Room Controller (RPC) 230 V
Warning
Hazard of Electric Shock: Remove all power from all devices before removing any covers or doors of the system. Disconnect power at the device and at the power source.
Electrostatic Discharge Required: Always discharge static electricity from your person by touching metal prior to handling any hardware. Failure to do so may result in damage to devices.
According to the documentation, it is not recommended to mix high and low voltage connections on the same side of the device.
There must be a minimum distance between terminals connected to High Voltage and terminals connected to Low Voltage of at least 5.5 mm to prevent the chance of voltage creep between the terminals.
  • MikaelKrantz25
