Low Battery Voltage (No Charger Trouble)
Select a Country
  • Low Battery Voltage (No Charger Trouble)
Sandeep_Kumar006 Troubleshooter
‎2025-07-24 08:05 PM
Last Updated: ContentModerator Explorer ‎2025-09-01 03:30 AM
The panel displays a Low Battery Voltage (No Charger Trouble) condition. This is accompanied by General Trouble and Power Trouble LEDs being ON.Low Battery Voltage (No Charger Trouble).png
ESMI Fire Detection.
  • FFSULH1001.
  • FFSULH1002.
  • FFSULH1003.
Warning
Hazard of Electric Shock: Battery terminals and leads are not power-limited. Short circuits can cause a fire or an explosion. Use extreme caution while connecting or disconnecting standby batteries.
Electrostatic Discharge Required: Always discharge static electricity from your person by touching metal prior to handling any hardware. Failure to do so may result in damage to devices.
The issue may arise due to one of the following scenarios:
  1. Newly Installed Batteries
    • Battery voltage may be low initially.
    • Allow the system to charge for a few hours.
    • The trouble condition should clear automatically.
  2. Panel Running on Batteries (No AC Supply)
    • Extended battery use without AC supply can drain voltage.
    • Once AC power is restored, charge for a few hours.
    • The issue should resolve itself.
  3. Panel on AC Supply but Still Showing Trouble
    • Batteries may be aged or degraded.
    • If the issue persists after charging, replace the batteries.
    • After replacement and charging, the panel should return to normal operation.
Scenario Action
New batteries
Charge for a few hours
No AC supply Restore AC supply and charge
Aged batteries Replace and charge
  • ESMI Fire Detection
  • SandeepKumar25
