Listview columns show a number but the meaning is not shown
  • Listview columns show a number but the meaning is not shown
  • DavidChild
    DavidChild
  • Dave_Shore
    Dave_Shore
Dave_Shore Schneider Alumni (Retired)
‎2021-09-27 02:17 AM
Last Updated: Sisko DavidChild Sisko ‎2021-09-27 02:17 AM
Andover Continuum
Listview
There is some data in a listview where the exact meaning of an integer is not clear.
There is a text file called stsvs.txt located in the Continuum folder that can be viewed to explain the integer to text relationship for many types of object.
An example is Activity "CallerCode" which only returns an integer value.
Searching the "stsvs.txt" files shows the equivalent text.
  • DavidShore21
