Heat Meter customer number and modbus address
  • Heat Meter customer number and modbus address
  • PeterEdvik
    PeterEdvik
  • DavidChild
    DavidChild
Sisko DavidChild Sisko
‎2019-08-13 11:12 PM
on ‎2019-08-13 11:12 PM
The Heat Meter now has a barcode where the customer number use to be printed. From the customer number the modbus slave ID could be determined.
Field Devices
  • Modbus
  • Heat Meter
The Heat Meter now has a barcode where the customer number previously had been printed. From the customer number the modbus slave ID could be determined.
The customer number is a replica of the serial number. The last 3 digits are the modbus slave ID, except when the last 3 digits are 248 or higher, then the slave ID is the last 2 digits.
In this case, the slave ID is 210.
  • Field Devices
  • DavidChild19
