Function Block Program Macro Library
  • Function Block Program Macro Library
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2023-10-27 05:43 PM
on ‎2023-10-27 05:43 PM
Using the Function Block Program Macro Library
Building Operation Workstation
The need for program examples on creating Function Block Programs
To assist with creating Function Block Programs, the EBO Function Block Program Macro Block Library is included in the EBO Workstation installation.
Here's how you can leverage the Macro Library:
  1. Access the Macro Library:
    • Open the EBO Workstation.
    • Navigate to the Function Block Program section.
    • Locate and access the Macro Library.
  2. Incorporate the Macro Library:
    • Once inside the Macro Library, explore the various pre-built Function Block Program macros available.
    • Select the desired macro that aligns with the specific function you intend to program.
    • Integrate the selected macro into your Function Block Program to enhance its functionality.
  3. Learn by example:
    • The Macro Library also serves as an excellent resource for learning and understanding how to program specific functions.
    • Study the structure and logic of the included macros to gain insights into effective programming practices.
    • Utilize the examples as a starting point to develop your own customized Function Block Programs.
The EBO Function Block Program Macro Block Library is designed to simplify and accelerate your programming tasks within EcoStruxure Building Operation. Leverage the library's resources and example programs to enhance your programming skills and efficiency.
  • MikaelKrantz23
56% helpful (5/9)
