Frequency of  Zigbee device SED-MTH-G-5045 sending its values
  • Frequency of  Zigbee device SED-MTH-G-5045 sending its values
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2022-11-15 02:57 PM
on ‎2022-11-15 02:57 PM
Field Devices.
  • Zigbee
  • SED-MTH-G-5045 Motion/Humidity/Temperature Sensor
Unsure how frequently the sensor updates it's values to the network.
Motion
Transmitted immediately on sensing of motion.
Temperature
  • Transmitted, by default at least once every 10 minutes.
  • If it has changed by 0.5 C or more, than it will be sent immediately with a limit on sending no more often than every 2.5 minutes.
    • Minimum interval = 2.5 minutes
    • Maximum interval = 10 minutes
    • Reportable Change = 0.5 degrees C
Relative Humidity
  • If it has changed by 0.5%RH or more, it will be sent immediately with a limit on sending no more often than every 2.5 minutes.
    • Reportable Change = 0.5% RH
These reporting rates are configurable for the sensor.
  • Field Devices
  • MikaelKrantz22
