Frequency of Zigbee device SED-CO2-G-5045 sending its values
  • Frequency of Zigbee device SED-CO2-G-5045 sending its values
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2022-11-15 03:10 PM
on ‎2022-11-15 03:10 PM
Frequency of Zigbee device SED-CO2-G-5045 sending its values.
Field Devices.
  • Zigbee
  • SED-CO2-G-5045 CO2 sensor with room temperature and humidity
Unsure how frequently the sensor updates it's values to the network.
The sensor has a Transmission Period (writable) that sets how often the device will send a measurement.
  • Default value = 150 seconds
  • Minimum period = 30 seconds
  • maximum period = 600 seconds
Note that there is also a “Night Mode” to help extend battery life. During “Night Mode”, the transmission period is multiplied by 4.
Night mode is entered when the CO2 level falls below the “Comfort Limit Value”, which is 600 ppm by default.
  • Field Devices
  • MikaelKrantz22
