Extending EBO Zigbee Wireless Mesh Using Repeaters
  • Extending EBO Zigbee Wireless Mesh Using Repeaters
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2024-09-11 06:21 PM
on ‎2024-09-11 06:21 PM
When a SED-TRH-G-5045 sensor is positioned outside the range of the main EBO Zigbee wireless mesh, what is the recommended method or product to extend the wireless coverage?
Building Operation Automation Server Premium
The SED-TRH-G-5045 is a Zigbee pro sleepy end device.
Any Zigbee router within the system can function as a repeater to extend the radio communication. The router should be positioned within the radio range of the sensor and within the range of the RPx or another router.
If a Zigbee device is powered by mains, it typically operates as a router. While there are currently no SE products designed solely with "repeater capability," several SE products possess router capabilities in addition to other capabilities,
  • SE8000 SpaceLogic room controller
  • Wiser plug CCTFR6500
  • Wiser Power Micromodule CCTFR6730
  • Wiser Room Thermostat with display CCTFR6400 or CCTFR6401.
We have not officially tested any 3rd party Zigbee routers, however the IKEA TRÅDFRI repeater is known to work effectively.
Labels (2)
  • Field Devices
  • MikaelKrantz24
