Esmi Ultima Touch Screen Calibration
  • Esmi Ultima Touch Screen Calibration
Ensign Sandeep_Kumar006 Ensign
‎2024-11-20 07:42 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:31 AM
If you are having trouble with the screen operation, you may need to re-calibrate the touch screen.
ESMI Fire Detection.
  • FFSULH1001.
  • FFSULH1002.
  • FFSULH1003.
Warning
Electrostatic Discharge Required: Always discharge static electricity from your person by touching metal prior to handling any hardware. Failure to do so may result in damage to devices.
During shipping, the touch screen calibration may become misaligned.
To calibrate the touch screen, do the following:
  1. Hold down the function button on the back of the main PCB and press and release the reset button, continue to hold down the function button firmly until the calibration screen appears this can take up to a minute
  2. Once the calibration screen has appeared you will be prompt with 5 crosshairs which you must press in turn.
Note: Please note when pressing these crosshairs ensure you use your hand as it has been known to cause issues using tools or stationery as pointers
  • ESMI Fire Detection
Tags (2)
  • SandeepKumar24
  • SandeepKumar25
