Esmi Ultima Network Card LED Status
Select a Country
  • Esmi Ultima Network Card LED Status
Sandeep_Kumar006 Troubleshooter
‎2025-05-05 05:42 PM
Last Updated: ContentModerator Explorer ‎2025-09-01 03:31 AM
Having issues with the panel's networking and unable to operate the touch screen or receive trouble messages on the screen.
ESMI Fire Detection.
  • FFSULH1009.
Warning
Electrostatic Discharge Required: Always discharge static electricity from your person by touching metal prior to handling any hardware. Failure to do so may result in damage to devices.
The display touch screen may not be working.
You can identify the current situation by checking the LED status as described below:
LED Status
LED indicators provide diagnostic information to identify communication.
LED Label  Name  Color  Description
LED 1 Heartbeat Red Identifies functional status.
LED 2 Tx Comms Green A blinking green light indicates that the module is transmitting data.
LED 3 Rx Comms Green A blinking green light indicates that the module is receiving data.
LED 4 Trouble Yellow A flashing yellow light identifies an error condition.
LED 5 Not In Use Green Not In Use
LED 6 Not In Use Green Not In Use
LED 7 Not In Use Yellow Not In Use
LED 8 Comms for SPI Bus Green Communication present when flashing
LED 9 Full Duplex Yellow Full duplex (on) half duplex (off)
LED 10 Ethernet Speed Red 10MHz (off), 100MHz (on)
LED 12 Communication Green Communication present when flashing
Refer to ESMI Ultima Networking Troubleshooting for further assistance with network related problems
  • ESMI Fire Detection
  • SandeepKumar25
