Esmi Transition tool stopped working after upgrading to SX-SOAP
  • Esmi Transition tool stopped working after upgrading to SX-SOAP
  • PeterEdvik
    PeterEdvik
  • AndreasP
    AndreasP
Ensign AndreasP Ensign
‎2025-01-23 05:33 AM
Last Updated: Janeway PeterEdvik Janeway ‎2025-01-23 05:35 AM
Esmi Transition tool stopped working after upgrading to SX-SOAP version 1.7.0.0 or higher
EcoStruxure Security Expert
  • EcoStruxure Security Expert
  • Esmi Transition Tool
  • SX-SOAP
The SOAP service no longer allows unencrypted communications over HTTP (port 8030)
Instead use HTTPS over port 8040.
1. Open Esmikko Database transition tool
2. Go to the tab "Data Sync Service" the change the SOAP Server Address from
http://localhost:8030/SecurityExpertSOAPService/service.svc to
https://localhost:8040/SecurityExpertSOAPService/service.svc or
https://SERVER_HOSTNAME:8040/SecurityExpertSOAPService/service.svc
Note: bolded characters in the second line
3. Click on the button Create Data Sync Service Settings File
The tool will stat working.
Tags (2)
  • AndreasP24
  • AndreasPettersen25
