Error message changing ES security settings in Webstation
  • Error message changing ES security settings in Webstation
  • PeterEdvik
    PeterEdvik
Janeway PeterEdvik Janeway
‎2022-08-23 06:27 PM
on ‎2022-08-23 06:27 PM
The following error message appears when trying to change the system security settings of an Enterprise Server in Webstation:
An error has occurred
Object protected
~/System/Security Manager/Global Security Settings
In Workstation the same settings are disabled (greyed out) and cannot be edited at all:
  • Building Operation Webstation
  • Building Operation Workstation
The probable cause of this issue is that the Enterprise server is part of an EC - ES multiserver system setup. Then some settings are in a Lead - Shadow relationship and can only be controlled from the top EC (Enterprise Central) server.
Edit these settings on the top Enterprise Central server.
  • PeterEdvik22
