ETD200-6 - IP rating
  • ETD200-6 - IP rating
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2025-10-19 05:17 PM
on ‎2025-10-19 05:17 PM
The IP rating for the ETD200-6 is not specified in the product documentation.
Field Devices
ETD200-6.
Documentation does not include the enclosure's IP rating, leading to uncertainty during specification or installation.
The enclosure of the ETD200-6 has an IP10 rating.
Note:
IP10 indicates limited protection against solid objects greater than 50 mm and no protection against liquids. This rating may affect installation environments where higher protection is required.
  • Field Devices
  • MikaelKrantz25
