EP Series Pressure Sensor Power Consumption
  • EP Series Pressure Sensor Power Consumption
  • DavidChild
    DavidChild
  • Gary
    Gary
Gary Schneider Alumni (Retired)
‎2022-02-18 05:07 AM
Last Updated: Sisko DavidChild Sisko ‎2022-02-18 05:53 AM
EP series information not available in documentation
Field Devices
Required information for planning installation.
The EP 3x series consumes maximum 20mA input power as determined in loop powered mode (4-20mA).
When in three-wire voltage output mode, up to 2 mA of additional current may be drawn from the load.
Further information is available on the Schneider Electric Exchange - EP Series Pressure Sensors.
  • Field Devices
  • GaryMontague22
