EOL resistor specification for RS-485 bus and input configuration
  • EOL resistor specification for RS-485 bus and input configuration
  • DavidChild
    DavidChild
  • PeterEdvik
    PeterEdvik
Janeway PeterEdvik Janeway
‎2020-03-18 02:21 AM
on ‎2020-03-18 02:21 AM
Tolerances for resistors when used for RS485 bus termination and EOL for double balanced inputs.
Security Expert
Wiring
Resistor specification required for ordering purposes.
330 ohm EOL resistors are required for the RS-485 bus and 1K ohm resistors for EOL zone (input) configuration.
  • 330 ohm = 5% tolerance, Metal film
  • 1000 ohm = 1% tolerance, Metal Film
  • EcoStruxure Security Expert
  • PeterEdvik20
100% helpful (1/1)
