Could not change settings under Poll Control for Zigbee device SED-MTH-G-5045
  • Could not change settings under Poll Control for Zigbee device SED-MTH-G-5045
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2022-11-15 02:32 PM
on ‎2022-11-15 02:32 PM
When changing values like Check-in interval (s) under Poll Control for Zigbee device SED-MTH-G-5045, the value seams not to have been change when opening the dialog again.
EcoStruxure Building Operation.
  • Building Operation Automation Server Premium (AS-P)
  • Building Operation Room Controller (RP-C)
  • non-Greenpower sensors SED-MTH-G-5045
Setting is sent to the sensor only once every tenth minute.
Open the dialog box again after 10 minutes to verify your changes.
  • MikaelKrantz22
