Changing the number of PIN code attempts for a door
  • Changing the number of PIN code attempts for a door
  • PeterEdvik
    PeterEdvik
  • HenrikTarpgaard
    HenrikTarpgaard
HenrikTarpgaard Schneider Alumni (Retired)
‎2019-09-16 01:54 AM
Last Updated: Janeway PeterEdvik Janeway ‎2019-09-16 01:56 AM
Is it possible to change the number of PIN code attempts for a door in Security Expert?
Security Expert
  • Security Expert Server 4.2.x
  • Security Expert Smart card Readers (any with a keypad)
By default, the number of PIN code attempts is set to three.
  1. In the Security Expert Client, go to Programming - Doors
  2. Select the door that you want to change and open the Commands field under the General tab
  3. Enter the command "LockOutAttempts=x", where x is the number of attempts (max number of attempts is 15)
  4. Save and download the changes to the Controller
  • EcoStruxure Security Expert
  • HenrikTarpgaard19
100% helpful (1/1)
