Capturing a photo using "Logitech HD Pro Webcam C920"
  • Capturing a photo using "Logitech HD Pro Webcam C920"
Commander Sampath_Konda Commander
‎2019-11-14 08:13 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:09 AM
Blank window while capturing a photo using "Logitech HD Pro Webcam C920".
EcoStruxure Security Expert
Security Expert
While capturing a user photo using "Logitech HD Pro Webcam C920", it shows up as an image source (in the drop-down along with Topaz). When selected however, the screen is blank.
With this webcam, you need LWS software by Logitech installed on your machine. G Hub has replaced LWS however it seems like G Hub is not currently functional with the integration. Find more information about the  "LWS280" driver HERE.
The driver can be downloaded from the attachment.
  • EcoStruxure Security Expert
lws280.zip
Tags (2)
  • AdamSteele23
  • SampathKonda19
