CE Declaration of Conformity Certificate for manufactured cables
  • CE Declaration of Conformity Certificate for manufactured cables
  • PeterEdvik
    PeterEdvik
  • DavidChild
    DavidChild
Sisko DavidChild Sisko
‎2019-08-13 11:00 PM
Last Updated: Janeway PeterEdvik Janeway ‎2019-08-13 11:02 PM
CE Declaration of Conformity Certificate for manufactured cables for interconnecting EBO modules.
Cabling
No CE Declaration of Conformity available for the SXWSCABLE10001 and SXWSCABLE10002 that connects EcoStruxure Building Operation AS-P and IO modules when fitted for example: when modules need to be mounted on separate DIN rails.
CE Declaration of Conformity certificate is not required for an item e.g. premanufactured interconnecting wiring that has no functionality or is inert to the operation of the system.
Europe – CE Marking
In general, CE Marking Directives are aimed at products, not at components, although there are some exceptions. Wire and cable products are one of those exceptions that stand out. On its own, wire or cable has no defined use or application, in that it must be built into something to be useful.
  • DavidChild19
