Alert, Confirm and Prompt in graphics on Advanced Display
  • Alert, Confirm and Prompt in graphics on Advanced Display
Janeway PeterEdvik Janeway
‎2020-05-12 02:50 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:59 AM
The TGML JavaScript methods alert(), confirm() or prompt() do not work on Advanced Display when using the Webstation app. Nothing happens when the methods are used, and the modal window that is expected is not displayed.
See attached TGML file for a graphic example using the JavaScript methods.
  • Building Operation Advanced Display V2
  • Building Operation Advanced Display V3
The embedded browser in the Webstation app does not support alert(), confirm() and prompt().
Use other ways to interact with the user that do not use modal windows. It is also likely that the usability of your graphics will benefit from removing the above mentioned JavaScript methods.
AlertConfirmPrompt.zip
  • PeterEdvik20
75% helpful (3/4)
