Alarm sequence number changes over time
  • Alarm sequence number changes over time
  • AbeMeran
    AbeMeran
Captain AbeMeran Captain
‎2022-12-08 05:04 PM
on ‎2022-12-08 05:04 PM
The sequence numbers for Alarm Events are changing daily for all active alarms in the system. This can be a problem for applications using sequence number as alarm identifier.
  • Building Operation Enterprise Server.
  • Building Operation Automation Server Premium
Every night there is a cleanup in the alarm table and alarms can then get new sequence numbers.
Every night historic updates with old time stamps are removed in the alarm table.
When this cleanup takes place, there is a reorganization of sequence numbers of current alarms. They all get a new sequence number.
The new sequence numbers are always higher than the latest sequence number before the cleanup.
Do not use alarm sequence number for alarm identifier, use triggered time stamp instead.
Tags (5)
  • AbeMeran22
  • alarm
  • change
  • number
  • sequence
