AS-P, CPU Temperature
  • AS-P, CPU Temperature
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2025-04-09 05:59 AM
on ‎2025-04-09 05:59 AM
What temperature limit should the CPU Temperature stay within?
EcoStruxure Building Operation.
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
From EBO version 3.2, the CPU Temperature is added.
The CPU temperature parameter displayed in the UI property dialog Automation Server Properties – Basic Tab is intended for internal debugging purposes only.
Users are not required to monitor or take action based on this value, as there is no specified maximum CPU temperature level that requires user intervention or indicates potential CPU performance degradation.
  • MikaelKrantz25
