Video: UPS Score assessment
Assessments
View recommendations and insights in the UPS Score, UPS Load, Device Security, Alarm, and Active Lifespan Alarms assessments in EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Reporting
  • Assessments
  • Video: UPS Score assessment
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Assessments
  • Mark as Read
Picard EcoStruxureIT
‎2020-02-16 06:37 PM
Last Updated: Sisko JLehr Sisko ‎2025-06-06 09:22 AM
View available assessments on the Reports > Assessments tab.
Click Download CSV in the UPS Score assessment tile to save the assessment.
Click Generate report to download the UPS Assessment report that contains data from both the UPS Score and the UPS Load assessments.
The UPS Score assessment evaluates the relative ranking of a UPS based on its state. The score is between 0 and 100, with 100 being the best possible score.
How is the Score calculated and reflected?
The score calculation is based on anonymous benchmarking of the following factors against comparable devices:
  • Temperature of the battery
  • UPS Age
  • Battery Age
  • If the UPS has either a Critical Alarm or a Lifetime Alarm, indicating end-of-life for the device
  • Unbalanced, for a 3-phase UPS, where the phases are not equally balanced
The scores are evaluated as being either:
Poor (0-33) displayed in red
Average (33-66) displayed in orange
Good (66-100) displayed in green
On the Assessments page, a quick insight into the distribution of assessed devices is indicated in the UPS Score.
Recommendations based on the score
Based on a factor in a score with a poor evaluation, a related recommendation is given. For example, if a battery is old, there is a recommendation to replace the battery.
On the UPS Score page, you can filter for a specific score or recommendation.
UPS_Score_Overview_360005843017.pngUPS_Score_Overview_360005843017.pngRecommendations appear on every tab in the UPS Score details page.
ITE_UPS_score_recommendation_1_360005843017.pngITE_UPS_score_recommendation_1_360005843017.png
Significant Changes
Since a significant change to any of the factors of the score will impact and update the score for the UPS, there is a dedicated view for all the significant changes that influenced the score on the Changes tab of the UPS Score details page.
ITE_UPS_Score_Details_changes_360005843017.pngITE_UPS_Score_Details_changes_360005843017.png
Alarms
Critical and lifetime alarms that impacted the score are displayed on the Alarms tab, with the title, description, and general information about the duration.
ITE_UPS_Score_Details_alarms_360005843017.pngITE_UPS_Score_Details_alarms_360005843017.png
Battery Wear
The latest addition to the UPS Score is an extension of the battery information, with details about the wear of the battery, on the Battery tab.
Tip: IT Expert Administrator users can now update the Last Battery Replacement date on a single device. See Single device configuration
Battery wear information is currently available for:
  • Single phase Smart-UPS
  • 3-phase Smart-UPS
  • Easy UPS 3S
  • Single phase Galaxy UPS
  • Some 3-phase Galaxy UPS only Supported Galaxy 3-phase UPSs
  • Symmetra UPS Supported Symmetra UPSs
Note: UPSs with lithium batteries are not included in the UPS assessment at this time.
The Battery tab contains three segments of information related to the wear.
  • Battery details indicates the current wear of the battery. When the wear is beneath the recommended threshold of 40%, the wear is indicated in red. The wear also indicates an expected end-of-life (EEOL) year and month for the battery. If the temperature of the battery is not optimal (25°C / 77 °F), an additional expected end-of-life at ideal temperature is given if there is at least one month of additional lifetime for the battery.
  • Main factors of wear indicates the impact of the three factors that contribute to the calculation of the battery wear: Temperature, Age, and the cumulative count of registered discharges (cycles).
  • Health projection is a projection of the decay of the battery over the time it has been monitored. The graph includes both the EEOL and the EEOL at ideal temperature, if present.
UPS Score details page on the Battery tab indicates a battery wear beneath the threshold of 40%
In case of available battery wear model data, the first tab will be extended with the battery health wear in percent.
ITE_UPS_Score_Details_Battery_Wear_360005843017.pngITE_UPS_Score_Details_Battery_Wear_360005843017.png
What does this mean for you?
The UPS Score assessment gives you insight into your UPS using a score calculated against comparable devices.
You can use the score as an indication of how close the components, or the device itself, is to its end-of-life, and determine whether the device is being used in an optimal way.
Life expectancy can vary greatly depending on factors such as whether you proactively perform routine maintenance.
Disclaimer
The UPS Score assessment gives the most accurate indication of the state of your hardware when you're using the latest Gateway version and a self-test has been run on the UPS.
