zelio soft2 Are vertical rungs possible? pic attached
  • Industrial Automation
  • zelio soft2 Are vertical rungs possible? pic attached
Bastian_Schmitz
35
LeTomas
14
RoozeeR
Lt. Commander RoozeeR Lt. Commander
6
JerryBartlemay
6
Joem1
Joem1
Cadet
Posted: ‎2024-01-12 03:53 AM
902
While learning programming I wondered if it's possible to make vertical "rungs"  that don't connect to horizontal rungs?  and if so how is this achieved?  pic attached.zelio question.png
Replies 4
Joem1
Joem1
Cadet
Posted: ‎2024-01-18 01:26 AM
Anyone?
puffnstuffuk
puffnstuffuk
Cadet
Posted: ‎2024-01-20 03:15 AM
817
In ladder logic programming, the typical structure involves horizontal rungs that read from left to right, mimicking the wiring diagrams used in traditional relay-based control systems. Each horizontal rung represents a logical condition or set of conditions.
Joem1
Joem1
Cadet
Posted: ‎2024-01-22 02:19 AM
In response to puffnstuffuk
I think I'm beginning to understand that, thanks!  I just thought when copying an existing Ladder logic diagram it would be easier to have an option to run a vertical connection between two rungs separated by several other unconnected rungs only so as to follow along the Ladder Logic diagram as observed printed inside a control box etc.
leofrench2345
leofrench2345
Cadet
Posted: ‎2024-10-11 08:46 AM
Zelio Soft 2, vertical rungs are not typically possible in ladder logic diagrams. Ladder logic is traditionally designed to flow from left to right and from top to bottom, representing the sequence of control logically and readably. The "rungs" of the ladder are horizontal, with power flowing from the left side to the right side.
