Why UnityPro V12. doesn't open?
  • Why UnityPro V12. doesn't open?
129
72
EcoStruxure™ Control Expert
jhonut1
Crewman jhonut1
Crewman
Posted: ‎2023-02-07 01:48 AM . Last Modified: ‎2023-02-07 02:03 AM
3479
I installed UnityPro V12. I have installed it without any error. When I want to open it, nothing happens. What should I do to be able to open it?
PS: I had instaleed it a while ago, but yesterday I installed EcoStruxure Control Expert v15. It unistalled my UnityPro. Now I want to come back to unity pro. I installed it but I am not able to open.
  • EcoStruxure Control Expert
  • UnityPro
Replies 7
MikaelKrantz
Guinan MikaelKrantz Guinan
Guinan
Posted: ‎2023-02-07 10:49 PM
3462
Did search on the Internet, and found: EcoStruxure Control Expert (Unity Pro).
So, it looks like Unity Pro today are the same as EcoStruxure Control Expert.
And, it is not common to be able to have more than one version installed, so my guess is that you can not have both.
jhonut1
Crewman jhonut1
Crewman
Posted: ‎2023-02-07 11:35 PM
In response to MikaelKrantz
Thanks for replying! I know I can't have both because when I installed EcoStruxure Control Expert over UnityPro, the last was uninstalled automatically. My problem was that after removing EcoStruxure Control Expert and reinstalling UnityPro, it didn't open. To make it work again, I had to restore Windows to a previous version.
MikaelKrantz
Guinan
Posted: ‎2023-02-08 02:08 AM
Do not know that program, however if it has like shared DLL files, you may have got newer once, and if shared, they may not be un-installed, and the old program not working with the newer files...
Restoring puts it back to the old status.
Milan1
Milan1
Cadet
Posted: ‎2024-02-29 01:17 AM
I have Unity Pro V13 and i also installed EcoStruxure Control Expert v15 then i delete it want to install V13 back again. Installation went trough without errors but when i launch program i get this error:
"Unity Pro XL Fatal Error
The thread tried to read from or write to a virtual address for which it does not havee the appropriate access"
Any advice what i should do?
Please note that system restore is not a option in my case.
Thx in advance.
Alderman
Alderman
Cadet
Posted: ‎2024-12-22 04:31 AM
2190
I have that exact problem
VOUS_ETES_PENIBLES
VOUS_ETES_PENIBLES
Cadet
Posted: ‎2025-06-24 06:45 AM
In response to Alderman
1254
Same problem. ANyone can help?
VOUS_ETES_PENIBLES
VOUS_ETES_PENIBLES
Cadet
Posted: ‎2025-06-26 12:01 AM
In response to VOUS_ETES_PENIBLES
Voici la réponse du support technique qui a fonctionnée pour moi. (Merci a eux)
Désinstallation de Control Expert via l'outil de désinstallation de Windows dans le panneau de configuration
Désinstallation des DTM via l'outil de désinstallation de Windows dans le panneau de configuration:
EcoStruxure Control Expert PsX DTM Library
A la désinstallation, cliquez bien sur "désinstallez toutes les sous applications" avant de cliquer sur suivant
Schneider Electric Placeholder DTM Library
SEMx80HartGatewayDTMLibrary
Schneider Electric BME NOR DTM Library
Schneider Electric PME DTM Library
CXM DTM
FDTENV64
Supprimer les répertoires suivants de votre disque dur, si ceux là sont encore présents:
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\SRCSDK
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\RAT
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\SSTA
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\Tlb
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\Common
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\CommonControlExpert
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\ControlExpert
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\Security
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\CetPrivateInterface
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\Generic Modbus TCP DTM
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\LOKI
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\PMEGenericDTM
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\PSxERIODTM
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\PSxM580_DTM
Suppression C:\Program Files (x86)\Common Files\Schneider Electric Shared\Unity Pro Generic EthernetIP DTM
Suppression C:\Program Files\Common Files\Schneider Electric Shared\ControlExpert
Suppression C:\Program Files\Schneider Electric\Control Expert 16.0
Suppression C:\Program Files (x86)\Schneider Electric\Control Expert 15.3
Suppression C:\Program Files (x86)\Schneider Electric\Control Expert 15.2
Suppression C:\Program Files (x86)\Schneider Electric\Control Expert 15.1
Suppression C:\Program Files (x86)\Schneider Electric\Control Expert 15.0
Suppression C:\Program Files (x86)\Schneider Electric\Control Expert 14.1
Suppression C:\Program Files (x86)\Schneider Electric\Control Expert 14.0
Suppression C:\ProgramData\Schneider Electric\Control Expert 16.0
Suppression C:\ProgramData\Schneider Electric\Control Expert 15.3
Suppression C:\ProgramData\Schneider Electric\Control Expert 15.2
Suppression C:\ProgramData\Schneider Electric\Control Expert 15.1
Suppression C:\ProgramData\Schneider Electric\Control Expert 15.0
Suppression C:\ProgramData\Schneider Electric\Control Expert 14.1
Suppression C:\ProgramData\Schneider Electric\Control Expert 14.0
Suppression C:\ProgramData\Schneider Electric\CommonControlExpert
Suppression C:\ProgramData\Schneider Electric\Topology Manager
Suppression C:\ProgramData\Schneider Electric\M580 Master DTM
Suppression C:\ProgramData\Schneider Electric\NORDTM
Suppression C:\ProgramData\Schneider Electric\PSx Ethernet RIO DTM
Suppression C:\ProgramData\Schneider Electric\PSx LOKI DTM
Suppression C:\ProgramData\Schneider Electric\PTK Generic DTM
Suppression C:\ProgramData\Schneider Electric\SECXMDTM
Suppression C:\ProgramData\Schneider Electric\Unity Pro Generic EthernetIP DTM
Ouvrir regedit et supprimez les clé de registres (si présentes):
  • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\Control Expert
  • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\Control ExpertConfCatalog
  • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\Control ExpertTypesLibrary
  • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\Control ExpertTMotion
  • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\securityeditor
  • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\Common
  • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\Generic Modbus TCP DTM
  • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\M580 Master DTM
  • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\PSx Ethernet RIO DTM
  • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\PSx LOKI DTM
  • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\Unity Pro Generic EthernetIP DTM
  • HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Schneider Electric\Unity FDTDTMCommon
  • HKEY_CURRENT_USER\SOFTWARE\Schneider Electric\Control Expert
  • HKEY_CURRENT_USER\SOFTWARE\Schneider Electric\Ecostruxure Control Expert PSx DTM Library
  • HKEY_CURRENT_USER\SOFTWARE\Schneider Electric\PME Generic DTM
  • HKEY_CURRENT_USER\SOFTWARE\Schneider Electric\RATsvr
  • HKEY_CURRENT_USER\SOFTWARE\Schneider Electric\Schneider Electric BME NOR DTM Library
  • HKEY_CURRENT_USER\SOFTWARE\Schneider Electric\Schneider Electric Placeholder DTM library
  • HKEY_CURRENT_USER\SOFTWARE\Schneider Electric\Schneider Electric PME DTM Library
  • HKEY_CLASSES_ROOT\Mx80MasterDTM.DTMCore
  • HKEY_CLASSES_ROOT\Mx80MasterDTM.DTMCore.1
  • HKEY_CLASSES_ROOT\PSxEIPMasterDTM.DTMCore
  • HKEY_CLASSES_ROOT\PSxEIPMasterDTM.DTMCore.1
  • HKEY_CLASSES_ROOT\PTK_GenericDTM.DTMCore
  • HKEY_CLASSES_ROOT\PTK_GenericDTM.DTMCore.1
Désinstallation avec l'utilitaire de résolution des problèmes Microsoft contenu sur cette page web:
https://support.microsoft.com/fr-fr/windows/r%C3%A9soudre-les-probl%C3%A8mes-emp%C3%AAchant-l-instal...
Lancer l'outil de diagnostic
choisir désinstallation puis dans la liste (si les éléments sont présents):
PSx Loki DTM puis lancez la désinstallation avec l'outil. Attendre que l'outil finisse.
Fermer l'outil et recommencer avec:
M580 Master DTM
BME NOR DTM
Redémarrer le PC
Réinstaller Control Expert avec le mode exécuter en tant qu'administrateur
Redémarrer le PC
