How to download hardware configuration without affecting process on M580 HSBY via control Expert15
Send InviteCancel
Posted: 2023-02-2402:03 AM
I am using M580HSBY PLC on one of my projects. I couldn't download hardware configuration, without stopping both CPU's.
A as a Primary, B as a standby. I started to download on standby CPU first.
standby CPU went to wait state, after that, i tried to download on primary CPU, the standby CPU didn't act as a primary. In that case, the process was affected.
In siemens there is one option to download on primary first and synchronized standby, without interrupting the process, since the standby on run mode.
