"Alert Action Scheduling" display
Alert Settings options
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • Alert Settings options
  • "Alert Action Scheduling" display
  • Mark as Read
  • EcoStruxure IT forum
EcoStruxure IT Support
Request Support
Back to Alert Settings options
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
Use this display to define the specific periods of time, for each day of the week, during which an associated activity will be disabled (by default, scheduling is enabled 24 hours a day, seven days a week).
Note
This display is used to schedule when an alert action will be enabled and disabled, using the action's settings display, or to schedule when a camera is enabled or disabled, using the "Surveillance Settings" display.
The table provides cells for 15-minute increments, and columns for every day of the week. You can do all of the following to schedule when an alert action, or camera, is enabled:
  • Click a column title to enable or disable all of that day's cells.
  • Drag your mouse from one cell to another cell in a column, to enable or disable a set of cells.
  • Drag your mouse from a cell in one column to a cell in another column, to enable or disable an identical set of cells for each of the selected days.
  • Click a single cell.
    Note
    The surveillance activity on a camera can also be scheduled directly on the NetBotz Appliance, and in the Data Center Expert client Surveillance perspective. The camera will not capture data when either the Data Center Expert server or the NetBotz Appliance has surveillance disabled; both must have surveillance enabled, to capture data.
Didn't find what you are looking for? Ask our Experts
