Test Action display
Alert Settings options
Send InviteCancel
Test an alert action after it is created or modified.
You need to verify the test was successful: the display does not report test failures. For example, for Send SNMPv1 Trap, verity the trap was received at the trap receiver, or for Send E-mail, verify the e-mail was received.
