Set Switch Output State display
Alert Settings options
  • EcoStruxure IT Help Center
  • Monitoring NetBotz Appliances in DCE
  • Alert Settings options
  • Set Switch Output State display
  • Mark as Read
  • Alert Actions option
  • "Alert Action Scheduling" display
  • "Activate Button Output" display
  • Test Action display
  • State alert thresholds
  • Send Wireless SMS Message display
  • Send HTTP POST alert action settings for NetBotz
  • Send Data to FTP Server display
  • Location macros for alert action settings on NetBo...
  • Identification macros for alert action settings on...
  • Deleting an alert action
  • Alert thresholds and supported devices
  • Alert profile sequences
  • Alert macros for alert action settings on NetBotz
  • Alert action severity settings
EcoStruxure IT Support
Request Support
Back to Alert Settings options
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
Define the settings for a Set Switch Output State alert action on a NetBotz Appliance.
A name field, severity selections, and the "Alert Action Scheduling" display that all alert action types share, are also available.
All time periods are enabled for an alert action, by default, in its "Alert Action Scheduling" display.
Element Description
Switch Output Device Select the switch relay device that will be triggered by the alert action from the list of all switch relay devices defined for use with the selected NetBotz Appliance.
Note
When no devices that support a switch output are monitored by the NetBotz Appliance, N/A is the only choice.
Switch State on Alert Select the state (On or Off) to which the selected switch relay device will be set when an alert occurs.
Switch State on Clear Select the state (Unchanged, On, or Off) to which the selected switch relay device will be set when the violated threshold returns to a normal state.
