We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on Cloud Connected vs On-Premise Services. Your feedback can help us shape the future of services.
Learn more about the survey or Click here to Launch the survey
Schneider Electric Services Innovation Team!
Positioning components in the floor layout
Adding equipment to the floor layout
  • EcoStruxure IT Help Center
  • IT Advisor
  • Building the ITA infrastructure
  • Adding equipment to the floor layout
  • Positioning components in the floor layout
  • Mark as Read
  • EcoStruxure IT forum
EcoStruxure IT Support
Request Support
Back to Adding equipment to the floor layout
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-06 07:13 AM
Positioning components closely together
Changing the layout to fine-grained might make it easier for you to position a component against another. Before moving the floor-mounted equipment in the layout, select Planning > Data Center in the Application bar and select to view a room in Floor Layout (by double-clicking the room that you want to add equipment to in Navigation).
  1. Drag the component icon into the position in the floor layout that matches its position in the data center:
    When you drag equipment, green highlights where it can be placed; red highlights where it cannot.
  2. If you cannot move the components close enough to one another, you can change the grid layout to fine-grained in the floor properties and use the snap to grid option to be able to move the components along the fine-grained grid lines.
    1. Right-click the floor layout and select Properties > Floor, and then select Fine-grained Grid layout.
    2. Right-click the component icon and select Snap to grid.
    3. Drag the component icon to the position of your choice.
      Tip
      You can move multiple items at the same time by using Ctrl-click or Shift-click.
Aligning selected components in the floor layout
  1. Select multiple pieces of equipment by using Ctrl+click or Shift+click.
  2. Right-click and select Align Equipment.
This is useful, for example if you have imported a big data center layout with some misaligned equipment.
Adding selected components to a new row
  2. Right-click and select Add to New Row.
You have moved the selected equipment into a new row in the floor layout. The new row fits the equipment.
This is useful to quickly create rows and position equipment, for example if you have a layout with both horizontal and vertical rows.
Didn't find what you are looking for? Ask our Experts
This is a heading
