Web Client not able to acquire data
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Web Client not able to acquire data
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
OsamaSalih
Lieutenant JG OsamaSalih
Lieutenant JG
Posted: ‎2024-01-09 02:37 AM
1287
Hi everyone
I am implementing a web client connecting to CitectSCADA 2016 WebServer. went through necessary steps to setup my client up yo web deplyment and everything went OK
when I run the the web client I get all webpages running but without the data assossiated with the Runtime
I would appreciate any help
P.S : when running a web client from the server machine itself everything goes just fine
  • Servers - Clients
Kien_Mac
Lieutenant JG
Posted: ‎2024-01-09 08:27 PM
1269
Hi Osama,
One place to check is that you have the Ports open on the webserver for the IO. Check the Technical Note or ports used by CitectSCADA.
Hope this helps.
Kien Mac
Technical Solutions Consultant
Kien_Mac
Lieutenant JG
1270
Hi Osama,
Hope this helps.
Kien Mac
OsamaSalih
Lieutenant JG
Posted: ‎2024-01-09 11:05 PM . Last Modified: ‎2024-01-11 08:24 AM
In response to Kien_Mac
thank you sir , I found that Windows firewall  was blocking the inbound traffic
Thank you for the enlightening
Regards
