Vijeo Citect 7.3x upgradation to Plant SCADA 2023
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Vijeo Citect 7.3x upgradation to Plant SCADA 2023
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
Mehak
Lieutenant Mehak
Lieutenant
Posted: ‎2024-04-18 11:23 PM
3383
Hi Everyone,
I want to upgrade my Vijeo Citect 7.3x to Plant SCADA 2023. My current point count is 15000. Kindly suggest the part number and suitable Plant SCADA 2023. The USB serial key is 0480-32650
Thank You in advance
  • Plant SCADA Runtime
olivier_vallee
Commander
Posted: ‎2024-04-22 05:08 PM
In response to Mehak
That license allows you to run a Server/Client role with up to 10 connectivity clients attached (e.g. CTAPI or OPC clients).
What is important is the version the license is able to run. When I put your key number into the GCS license tool, it says that this license is out of support and is only able to run v7.30 product.
Getting the key back into support will allow you to update the key to run the latest software (2023 R2 / v8.50).
Please get in contact with your distributor to discuss the options of getting this key back into support.
Kien_Mac
Lieutenant JG
Posted: ‎2024-04-22 08:25 PM
Full License means you can run as a Full Server IO/Alarm/Trend/Report.
Connectivity (API/OPC) means you can connect upto 10 ctAPI / OPC Connections
Drivers All means you are licensed fto use all drivers.
Networking allowed means you can connect View/Control Clients to the Server using this license.
Kien Mac
Technical Solutions Consultant
Replies 5
olivier_vallee
Commander
Posted: ‎2024-04-21 03:00 PM
Hi @Mehak,
I'd recommend reaching out to your AVEVA Sales representative (or Distributor) to get this key back into support. This will allow you to run the latest version and receive monthly software patches.
The latest version of AVEVA Plant SCADA is 2023 R2. The "Installation Guide" PDF on the ISO/ZIP also has a section on upgrading with all the details on how it can be done.
Kien_Mac
Lieutenant JG
Posted: ‎2024-04-21 05:09 PM
Hi Mehak,
There has been step changes to Point Counts to align all AVEVA HMI/SCADA.
* 75,150,500 -> 1K
* 1500 -> 2.5K
* 5K -> 10K
* 15K, 50K -> 100K
* Unlimited.
If an end user is in current support or get back into CF Support, they would have access to update their USB keys to the latest version via AVEVA License Website.
https://softwaresupport.aveva.com/LicenseGenerator/Citect/#?selectedTab=LicenseGenerator
Otherwise, they will need to purchase an upgrade, which will entail upgrading these points at a cost.
Please contact your local SE representative to get a quotation.
Kien Mac
Mehak
Lieutenant Mehak
Lieutenant
Posted: ‎2024-04-22 05:36 AM
3317
Thank You for the reply. I have 1 full license. 10 connectivity (API/OPC), 10 OLEDB connectors, drivers all supported, networking allowed, What does that mean? Please explain
Thank You
olivier_vallee
Commander
Kien_Mac
Lieutenant JG
Kien Mac
