Saving Alarm Data to SQL Server in Citect SCADA / AVEVA Plant SCADA
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Saving Alarm Data to SQL Server in Citect SCADA / AVEVA Plant SCADA
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Citect SCADA
AVEVA
AVEVA™ Plant SCADA
Back to AVEVA Plant SCADA Forum
sunilclakum
sunilclakum
Cadet
Posted: ‎2025-10-10 10:29 PM
421
I am currently working with Citect SCADA 2018 and have also tested the configuration in AVEVA Plant SCADA 2023 R2. I have successfully configured alarms in the editor and can view them on the SCADA runtime screen.
Now, I would like to store the alarm data in a Microsoft SQL Server database, including the following details:
  • Alarm message
  • Normal time
  • Acknowledge time
  • Reset time
  • Logged-in user name
Could you please guide me on how to configure or implement this functionality? Any example, documentation, or best-practice recommendation would be greatly appreciated.
  • Plant SCADA Runtime
  • Plant SCADA Studio
olivier_vallee
Commander
Posted: ‎2025-10-14 09:40 PM
390
Hi @sunilclakum
It is best to consult the online documentation for more details, but here is a high level guide on how to achieve this:
  • Set up SQL database: Create database, table with required columns (e.g., timestamps, alarm details, user), and ODBC DSN.
  • Configure SQL device: In Plant SCADA Studio, add SQL device with connection string, format string for fields, and INSERT command.
  • Enable logging: Set Log Device in alarm categories to the new device name.
  • Test and verify: Trigger alarms in runtime, query SQL table for records.
Kind regards
Olivier
sunilclakum
sunilclakum
Cadet
Posted: ‎2025-10-14 10:14 PM
In response to olivier_vallee
Hi @olivier_vallee
Thank you for your detailed guidance.
I have already completed the steps you mentioned — the SQL database and tables are created, the SQL device is configured, and logging is enabled under the alarm categories. The alarms are visible in the runtime window, but they still aren’t being logged into the SQL Server table. Please find the below attached screenshot for more details.
AlarmingSetup
AlarmSetup
AlarmWindow
DeviceSetup SQLSeverTable
Could you please advise if there are any additional settings or troubleshooting steps I should check?
Kind regards,
Sunil Lakum
olivier_vallee
Commander
Posted: ‎2025-11-02 02:28 PM
Hi @sunilclakum
It is tricky to debug these issues on a forum. It might be more efficient to get in contact with AVEVA Technical Support and do a live session debugging this.
If you are confident that you have the configuration setup correctly, you might want to check the syslog for any error messages. You could also setup a SQL Profiler in SMSS to trace messages sent from Plant SCADA to the SQL database.
And finally, there is a an example of SQL database access in the Example project. See pages "DatabaseAccess" and the cicode file DBAccess.ci for more details.
Kind regards
Olivier
