Plant SCADA 2023 Generic Protocol valid variable name
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Plant SCADA 2023 Generic Protocol valid variable name
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
macnite
macnite
Cadet
Posted: ‎2024-10-22 05:54 AM
1119
I am using AVEVA Plant SCADA 2023 and trying to add a TIMESTAMP variable to an internal IO device known as DISK_DRIVE which uses the Generic protocol.  When I compile, I get the following error:
Bad IO Device variable (E2014)
Apparently this is because the Address "T1" is unacceptable for a TIMESTAMP data type in the generic protocol, but I can't find a reference that tells me what an acceptable address is for that data type in that protocol.  Where do I find a reference which will tell me what I can use?
  • Plant SCADA Studio
olivier_vallee
Commander
Posted: ‎2024-10-23 08:41 PM
Hi @macnite,
Variable Tags don't support the data type "TIMESTAMP". This is a data type for use in Cicode. Please see the Cicode reference for variable data types here:
https://docs.aveva.com/bundle/plant-scada/page/1130160.html
If you open up the file \Plant SCADA\Bin\Generic.dbf it contains the schema for the generic protocol address format (see extract):
TEMPLATE COMMENT
D%U Digital
I%U Integer
R%U Real
L%U Long
S%U String
DIGITAL%U Digital
INT%U Integer
REAL%U Real
LONG%U Long
STRING%U String
I think can safely define this tag as a LONG, say "L1" and it will compile.
You should then be ok to use this Generic DISK device variable within Cicode in the place that requires TIMESTAMP values, since Cicode will automatically convert the LONG datatype into the expected TIMESTAMP datatype for you. See this section for more information:
https://docs.aveva.com/bundle/plant-scada/page/1130158.html
Kind regards
Olivier
olivier_vallee
Commander
Hi @macnite,
TEMPLATE COMMENT
D%U Digital
I%U Integer
R%U Real
L%U Long
S%U String
DIGITAL%U Digital
INT%U Integer
REAL%U Real
LONG%U Long
STRING%U String
Kind regards
Olivier
