OFS, Citect variable already deleted
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • OFS, Citect variable already deleted
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
BasVanDiepen
BasVanDiepen
Cadet
Posted: ‎2024-12-13 04:49 AM
716
Is there anyway to debug the message 'Citect variable already deleted' entering the Diagnostic Window?
Customer is using OFS 3.63 spk 3
  • Communication Drivers
olivier_vallee
Commander
Posted: ‎2024-12-15 02:59 PM
Hi Bas,
Long time no speak! I hope you are well.
Are you using the OFSOPC driver or is it a 3rd party OPC Client and you are interested in just the OFS side?
From a previous support case, with this error, the following response was given:
"This message is displayed at the reception of a read answer associated to an item that does not exist anymore.
It can happen when the item has just been removed before the read answer reception.
Note : We don’t see this kind of warning message when using Vijeo Citect because Vijeo Citect doesn’t remove the item, it deactivates it instead of.
It is more an informational message than a real warning. It indicates that the read answer will be ignored."
I'd recommend enabling driver logging (if OFSOPC is used on Plant SCADA side) to better understand what is happening.
Enable the following citect.ini settings:
[OFSOPC]
DebugLevel=ERROR | WARN
DebugCategory=ALL
It would be good to also cross reference the data dictionary (or variable data base) that OFS is using and if it matches the PLC program.
Kind regards
Olivier
BasVanDiepen
BasVanDiepen
Cadet
Posted: ‎2024-12-17 02:46 AM
Olivier, Thanks for your response. This is the OFSOPC-protocol with OFS 3.63 spk 3. I will ask the customer to add this parameters and will open a support ticket if it captures something we can't explain.
olivier_vallee
Commander
Posted: ‎2024-12-17 02:55 PM
Hi @BasVanDiepen,
Would be good to know what settings the customer is using in OFS, if they have enabled Data Dictionary or if they manually save/export the tag database from the PLC.
Good luck with it, hope it can be resolved.
Kind regards
Olivier
