No server could be found
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • No server could be found
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
Nizami225
Nizami225
Cadet
Posted: ‎2024-02-15 02:13 AM
1178
Hi everyone.
I cannot run my project using  my network IP address. It only runs on 127.0.0.1. But when I change it to 192.168.x.x all servers are not found. Here are some of my Topology settings:
Errors at runtime:
Perhaps a firewall issue or something else? Or do I have the wrong settings?
Any advice would be appreciated.
  • Alarms
  • Plant SCADA Studio
  • Servers - Clients
olivier_vallee
Commander
Posted: ‎2024-04-21 02:51 PM
Hi @Nizami225,
Unfortunately those images are not coming through for me, so I can't see your topology.
Run a command prompt with IPCONFIG to see what IP addresses are on the local machine. If you setup your IPv4 address correctly in the Topology > Network Addresses, it should work as expected. If you run the computer setup wizard and it is not detecting that this is a Server role (since IP matches what is configured) there could be something else at play. I doubt it is Firewall related, unless you have many machines in the system. If you are still stuck, I'd recommend reaching out to customer support and initiate a live chat session or remote screen sharing session to walk through your config.
olivier_vallee
Commander
Hi @Nizami225,
