M580 with Latest AVEVA Plant SCADA 2020R2
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • M580 with Latest AVEVA Plant SCADA 2020R2
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Modicon M580
Back to AVEVA Plant SCADA Forum
keithkcchan
Ensign keithkcchan Ensign
Ensign
Posted: ‎2021-08-26 07:43 PM
3242
There are two ways to communicate between M580 and AVRAV Plant SCADA over Modbus TCP/IP.  What is the suggested/recommended protocol to use for an around 25K tags AVEVA Plant SCADA with M580 PLCs, MODNET or OFSOPC??
I notice there are some issues on OFS with the older versions not not sure any issue or limitation with the current version 3.62 now before my mass deployment. Thanks in advance for your comments and feedback.
  • 02. Modicon M580 ePAC
  • AVEVA Plant SCADA
  • m580
  • modnet
  • OFS
MVT
Crewman MVT Crewman
Crewman
Posted: ‎2022-02-18 12:00 AM
Well.. In my view if you looking for cross platform and you are planning to move from old hardware to newer hardware versions of controller and devices (IOT compatible) with cybersecurity and its always advisable to use OPC UA/OPC UA Embedded (NUA) over OPC DA as it brings in the Cybersecurity aspect into consideration and also cross platform support as the later OPC DA only supports the Windows OS and not much of security to say be it 25K/50K tags.
Secondly, regarding some issues you are facing I'm not very clear on the exact problem you are facing with OFS. You should upgrade the OFS versions compatible with your SCADA.
PatrickVanDijk
Lieutenant JG PatrickVanDijk
Lieutenant JG
Posted: ‎2022-02-18 12:23 AM
I would suggest using OFSOPC for projects with a large amount of tags. The latest OFS versions no longer have the problems you are referring to. MODBUS (MODNET driver) is neither user friendly nor fast enough for large projects.
I have a project with 200k tags in 12 PLCs running via a single OFS server without problems.
The OPC/UA drivers in PlantSCADA are fairly new, so I have no information yet about performance or reliability. I would avoid them for now.
