A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
Posted: 2024-11-28 07:50 AM . Last Modified: 2024-11-28 07:55 AM
I have a mining application, where from time to time I add a PLC via Modbus TCP IP, I currently have around 9 PLCs connected, the last time I tried to add a PLC and start the application, the application does not start and the following message appears: RuntimeManager: "The citect process (cluster1.loss_server) is stopped
Posted: 2024-12-01 06:18 PM
Hi @diego-arrasco,
I'd recommend reaching out to Citect technical support to help troubleshoot this issue.
If I was debugging this, I would look at the syslog.IOServer.Cluster1.IOServer1.dat file in a notepad editor to see what errors are logged there. It might be that you just need to tune some parameters in the citect.ini to get it working.
Let us know what you find and how you go with support.
Kind regards
Olivier
