Fail to compile. Error - Graphic Common Galaxy Config Factory
AVEVA Plant SCADA Forum
A support forum for AVEVA Plant SCADA (formerly Citect SCADA). Share new and exciting product information, connect, learn, and collaborate with the ecosystem of Plant SCADA Users. AVEVA Plant SCADA a reliable, flexible and high-performance Supervisory Control and Data Acquisition software solution for industrial process customers. This forum is to connect, share, learn and collaborate new and exciting product information. Feel free to join and share to your Ecosystem of Plant SCADA Users.
  • Industrial Automation
  • AVEVA Plant SCADA Forum
  • Fail to compile. Error - Graphic Common Galaxy Config Factory
olivier_vallee
Commander olivier_vallee
34
Oncom
Commander Oncom
6
Kien_Mac
Lieutenant JG Kien_Mac Lieutenant JG
2
Back to AVEVA Plant SCADA Forum
Shafizan_Baharudin
Crewman Shafizan_Baharudin
Crewman
Posted: ‎2024-02-09 12:43 AM
1013
How to solve Error - The type initializer for 'Schneider Electric.Graphic.Common.GalaxyConfigFactory' threw an exception
  • Industrial Graphics
  • Plant SCADA Studio
Shafizan_Baharudin
Crewman
Posted: ‎2024-04-23 11:00 PM
In response to olivier_vallee
Hi @olivier_vallee,
Thank you for your reply. issue has been solved temporary. Problem is comes when installing Eco Structure Machine SCADA Expert to the same PC has AVEVA Plant SCADA . Seems like the program is overlap. No more issue when uninstall the software.
Version of software i am used.
1. AVEVA Plant SCADA 2020 R2
2. Eco Structure Machine SCADA Expert 2020 SP2
olivier_vallee
Commander
Posted: ‎2024-04-22 08:24 PM
922
Hi @Shafizan_Baharudin,
I've not ever seen an issue in this component. Can you share what version of Plant SCADA you are using? Was there anything that occurred to cause this issue (change in project, another software package installed)?
This appears to be in the AVEVA Industrial Graphics component. You could try "end task" the Scada.Graphics.Editor.exe if it is still running. Could you also try compiling another project, to see if it is configuration specific. If still not having any luck, I'd recommend reaching out to Support to troubleshoot this further.
Shafizan_Baharudin
Crewman
Hi @olivier_vallee,
olivier_vallee
Commander
Posted: ‎2024-04-28 07:11 PM
That makes sense. Since both products ship the Industrial Graphics feature, they don't co-exist nicely, since each tries to register the DLLs and file paths in the registry, hence conflicting. The R&D team responsible for Industrial Graphics has been made aware of this issue (long time ago) so hopefully they will address this in a future release, to allow multiple products to co-exist on the same machine.
